JUST STARTED TO BAG MY NEW 06 TACOMA REG CAB(TRUE MINI) IVE DONE MANY TRADIONAL BODY DROPS BUT NO STOCK FLOORING JUST A FEW QUESTIONS {NEED SIMPLE ANSWERS NO BASHING}
1. THE FRAME IS 6"X 2" C SHAPE! CAN I JUST INSERT SUM 2 x 3 BOX TUBING IN THE C SHAPE LOWER THE BODY MOUNTS AND SCALP OFF THE TOP OF THE FRAME??????
2. DO I HAVE TO REMOVE THE HOLE CAB OR CAN I JUST LIFT IT LIKE 6" OFF THE FRAME REALLY DONT WANT TO DRAIN ALL FLUIDS ESPECIALLY THE A/C
3. WHAT R SOME ISSUES TO CONSIDER(LINES,STEERING)
4. WHAT ABOUT THE TRANNY AND DRIVE SHAFT TUNNEL DO U RAISE THEM? I HAVE ABOUT 2" BETWEEN THE FLOOR AND TRANNY! I WAS THINKING DOING 2" STOCK FLOOR AND 2" TRADIONAL
LITTLE GUIDANCE NO BASHING!!!!
cookiemonster13
with carfeul work you can do it with out even lifting the cab up. you should be fine with 3x2 tubing since that frame is 6" make sure you scab over the front frame rails where you tie the new and original together. your steering may need a knuckle or some moving. i would not suggest cutting the floor completly. you probabbly will have to raise the tranny tunnel and the driveshaft tunnel a bit but factory carpet should fit back in. hope this helps some.
