Watts Link and 2x2 Lowers
dragmatic@aol.com's avatar
dragmatic's avatar
dragmatic
Hey guys. I want to run my bags on the lower 2x2 bars like is pretty normal these days. I wanted to do something a little different though since Watts links are almost non-existent around here. Is it going to be okay to run only the two lower bars and the watts link or am I still going to have issues. I know there are several very suspension savvy folks on here who can help me out. Thanks.
mindlissmetalfab's avatar
mindlissmetalfab
huh? you can run 2 lowers solid mounted to the axle and the watts if you want a 2 link. Your pinion angle will still suck, but you wont have any side to side movement.
Or u could run a parallel 3 or 4 link and the watts and have no side to side movement and minimal pinion angle change throughout travel. Just like a proper suspension!
DawgsledMazda's avatar
DawgsledMazda
hes right, add two upper bars and use the watts. it looks great and works the best of any suspension you can run.
s10
last post by baha +1y
