I was wondering if 3/16 would be thick enough for rear bag brackets? if not what i should use. thanx
FADE2BLK94
3/16" is fine
kevin@aac
1/4" is better! depends if its gusseted properly
91 drggn dime
lets not get into this arguement again.
3/16 is fine. stuff was made out of that for years, like 15 in this sport before SD started using 1/4 and now its the only thing to use.
Hell funny cars use 3/4" OD link bars and they take more abuse then any 1.5" OD 1/4" ID 4 link we use in this sport! (no i'm not saying go use 3/4" tube, geesh)
whynotfab
Depends what type of bracket itll be also, 1/8" is fine (circle plates) if its for a cup type bracket.. otherwise 3/16 or 1/4", all depends on what exactly you're doing, and how it's gusseted.
what type of bracket are you making?
travis98s10
3/16 is more than enough. you could use 1/8 if its welded and gusseted right
