Air Zenith
bagged89s10@hotmail.com's avatar
Air Zenith
bagged89S10's avatar
bagged89S10
Any feedback about the new Air Zenith compressors? Any problems with any yet?
FreelandKustomz's avatar
FreelandKustomz
ok im going to settle this Air Zenith crap right now........Ive had a vair 380, and my friend has a 480, and those are the only other major competiting compressors with air zenith, For one. Air zenith has a Greater CFM output. almost double those of the others. and its 100 percent duty cycle, these things dont slow down for one second. and compared to an oasis, the other bad ass compressor out, the amperage is supremly lower on a AZ Compared to a oasis, AZ being 35 amps each, and a Oasis being 150 each, and two az are 70 amps which is pretty damn close to the performance of an oasis, ive had my comopressors for nearly two months and never once had one problem with them. i suggest one thing, that is to run heavy gauge wire to these things. they are hungry and you gotta get them what they need. i upgraded to a yellow top and 4 gauge wire and i have had zero over heating problems with the wiring. With a 5 gallon tank, from 0 psi to 200 psi its roughly 4 min. and from 165 - 200 psi its only 50 seconds or less. They come with check valves and 3/8 braided line which is fine, i upgraded to 1/2 " line and bigger check valves under my own preferance but the fill time wasnt much of a difference. But if you got the cash fork that shit over and get a AZ!!!!
86RED's avatar
86RED
I SECOND THAT MOTION!!!!!!!! AZ KICKS A$$!!!!!!!!!!
95LayingBody's avatar
95LayingBody
My AZ and a 7 gallon tank comes in today and I cant wait... I will most likely go get me a yellow top also not too sure yet
whynotfab's avatar
whynotfab
Check out this thread, alot of good info:
Air Zenith Facts & Info
s10
last post by baha +1y
