Front toe issues, normal?
W
1loblzr
Ok this is for guys with s10 chassis and those who were lucky enough to get there upper and lower control arms from byc. Ive got byc uppers and lowers on a 95 4dr blazer with belltech 2" spindals, at ride height camber and toe is ok, obviously layed out its got negative camber, but it also toes out alot. Do others with s10's or others even do the same thing? If so how bad is is to drive on the highway, mines not legal to drive yet (inspection etc) so putting around the neighbor hood i cant tell much.
sjudd86
your gonna need an alignment after you put the control arms on. just be careful driving, i knock mine out all the time, it pisses me off
lkrayzie's avatar
lkrayzie
my yota toes in when i lay it out because my tie rods were hitting the rails. but thats a toyota
1loblzr
i aligned it when at ride height, but when aired out is when the front wheels toe out quite a bit, might be normal, just gettin feedback from others
jmn444's avatar
jmn444
I've got the belltech spindles on my F150, and they completely fucked up the design of them. I had to flip the tierod to make it come close to working correctly. For some reason, they moved the tierod mount point up 2" right along with the hub, and that throws the geometry way the fuck off. Not sure if they did that with other spindles or not, I used 2" spindles on my 1st gen S10 years back with no problems at all. Anyway, I guess my point is that Belltech needs to work out some serious kinks, I really doubt it's control arm related at all.
4uh8rs's avatar
4uh8rs
I HAVE THE SAME PROB WITH MY S10 BLAZER.I AM RUNNING A R T ARMS .I THINK I HAVE IT FIGURED OUT BUT I WANNA MAKE SURE IM RIGHT B4 I POST SO I DONT MAKE THINGS WORSE ON YOU GUYS.
DragDoorOn24s
if both wheels toe out and u get alighned to fix the toe when ur all the way lifted doesnt it toe in
4uh8rs's avatar
4uh8rs
THE TOW PROB IS AT FULL LIFT OR LAYD THE WHEELS TOE BOTH DIRECTIONS AND SOMETIMES TOGETHER AND SO FORTH.
BodyDragginGMC's avatar
BodyDragginGMC
Art arms do it to on my Sonoma.
1loblzr
Ok mine would basically do the same thing, i just havent actually measured it lifted all the way up, but yes it would continue pulling the toe in the higher it goes, I cant wait to actually drive it and see how bad the bumpsteer is! But these replies tell me Mines not any different from others. Thanks peeps!
s10
last post by baha +1y
