how to schrader valve
I
iceman9669
is there a fitting i can use to hook up a shcrader valve to 1/4" DOT airline, and if not then how could i hook up a schrader valve to the 1/4"DOT airline? thanks alot!!!
maz duh's avatar
maz duh
You will need the Shraeder valve(1/4 NPT) a female(both sides) 1/4 NPT coupler and a 1/4 NPT PTC fitting. Take all of the pieces and assemble them with a little teflon tape to seal the fittings and your done. You can now inflate your bags in an emergency.
Low_SST's avatar
Low_SST
you need this and a coupler and a 1/4" npt 1/4 tube ptc or compression fitting.
whynotfab's avatar
whynotfab
Edited: 1/1/2006 6:43:30 PM by WhyNotFab
You could always use one of these also,
Inflation Valve w/ 1/4" Line Fitting, Nut for mounting somewhere.
low mazda's avatar
low mazda
that is a schrader valve, just with a longer shaft that is threaded so you can mount it through something...like behind your tag or something.
I
iceman9669
so it is really just that easy... thanks alot guys!
whynotfab's avatar
whynotfab
yep, and ready for 1/4" line.. no coupler/straight needed
I
iceman9669
now where can i get these items at?????
LaidNeon's avatar
LaidNeon
i order my fittings from O'Reilly's from their Commercial Truck catalog
baggeddogs's avatar
baggeddogs
you can come by the shop justin, we keep them in stock...
s10
last post by baha +1y
