3 or 4 inch blocks on 2 link bars
LX
lo xploder
i have 2" blocks on my two link bars currently. i am thinking of putting 3" or 4" blocks in there to go lower , but will it take away some lift by adding the extra room for the blocks? i have way too much lift anyways
bodydropped85's avatar
bodydropped85
it will take away lift and make ur pinoin angle more shitty. i have no blocks on mine, just a machined 2 degree pinion shim.
LX
lo xploder
it shouldnt make the pinion angle terrible , the 2 link does that the lower you go i know that.
TD
the dirty 10
Edited: 12/29/2005 2:40:11 PM by the dirty 10
do you have a panhard bar yet?the pic in your profile of the two link is the rearend connected to the bars? if so how much ground clearance you got from the bar to the ground?
LX
lo xploder
yeah the panhard is on there now, that pic was in the middle of install the link bar was not attached, just hanging off the mount
and yeah at max drop the link bar touches the ground. i am going to redo the 2 link by moving the bars back to mount where the frame starts to turn up.
bodydropped85
y not just 4 link it? or move the bars to the inside of the frame?
LX
lo xploder
i like the way the 2 link handles/rides. and the gas tank is in the way. only other recourse is a 50/50 cuz i aint movin the tank.
LX
lo xploder
what do you think about movin the bars mounting points back to where the frame starts to bend upward so i wont drag the links anymore? i know ideally that the link bars are to be as long as possible but, in this case i am limited.
TD
the dirty 10
are you using the bottom of the frame as the upper bag mount?
LX
lo xploder
yeah, kind of. There is an L bracket under the frame for the bag mount.
s10
last post by baha +1y
