Sectioned Oil Pans?
ashtro@shaw.ca's avatar
Sectioned Oil Pans?
stromad's avatar
stromad
Is it possible to section an oil pan? And if so are there any problems i should worry about?
cookiemonster13's avatar
cookiemonster13
yes you can section just make sure you dont remove to much and dont have any oil capacity also make sure the oil pickup is still at the bottom of the pan.
time1's avatar
time1
I SECTIONED MY OIL PAN ON MY YOTA...I TOOK ABOUT 3/8 OF AN INCH OFF THE BOTTOM OF IT. JUST MAKE SURE YOU WELD IT UP GOOD SO IT DOESNT LEAK.
DEPENDING ON HOW MUCH YOU CUT IT YOU MIGHT HAVE TO MESS WITH YOUR OIL PICK UP TUBE.
GOOD LUCK!!
boooghar's avatar
boooghar
yea its possible, you hafta shorten your pick up tube also and sectioning you oil pan reduces the amount of oil you have in your engine unless you did something like a remote oil filter and used a bigger filter to make up the difference of the capacity you originaly lost.If you stick with the stock filter and the sectioned pan, you would need to change yuor oil more often since you have a lesser amount going thru your engine causing a shorter oil life
