WTB Axle pads
WTB Axle pads
kevin@aac avatar
kevin@aac
I know there is a 1000 buisness's on here. Who has a nice 3" axle pad with a low profile that will bolt to a Slam bag. Laser cut, quality piece?
Dont say Suicide doors, because there's sits up to high, and I dont like it. Pics would help
kevin@aac avatar
kevin@aac
Edited: 12/10/2005 7:40:45 AM by BagedRanger
here is an example
kevin@aac avatar
kevin@aac
Not this high, just this quality with a fair price! who has them. I want to support these companies I hear so much good things about and that support this site.
hopsing avatar
hopsing
Well, more then likely, most of them will be fairly tall. You need room to be able to get a bolt in from the underside between the axle and the pad. You could check AirRide Technologies, they have a bunch of different universal brackets and stuff. They seem to be a little more expensive, but I guess you could consider the price fair if you dont want to make it yourself and no one else makes them either.
dssur avatar
dssur
here is an example
You'll need a "forever bolt" if you use something that short. You know, install the bolt before you weld the perches on, so you can just spin the bags on and use a box wrench to hold it still and tighten it.
Sucks trying to line up the top bolts if you do that though..
And those are axle pads for leaf springs, the holes are for the pins in leafs. You could use them as bag mounts though..
bdroppeddak avatar
bdroppeddak
www.gravity-werx.com mikes are pretty low profile.
Lonoma2k avatar
Lonoma2k
here is an example
Yea Russ, thats the lower mounts that i have on my sonoma, i had to weld the bolt on from the under side, then weld on the mounts, i think i got em out of a 4wd lift kit or something, but yea they are pads for leaf springs....
Lonoma2k avatar
Lonoma2k
here is a link to some bro.... they are 16.99 and look exactly like what i have...good luck
http://www.jackit.com/store/supercart.cgi?s=wrr_200
whynotfab avatar
whynotfab
Found some a few bucks cheaper for you at Speedway Motors:
Here's the link
kevin@aac avatar
kevin@aac
Ok Im still looking. nobody out there has
a low profile lower bag mount for on top of the axle?
