brakelights wont work
ojhk@hotmail.com's avatar
tha mazda's avatar
tha mazda
I dont know what is wrong with my brake lights i replaced the fuse even though the fuse was still good just to see if maybe thats what was wrong with it but they still dont work at all i dont know what to do. Can anyone help me please? ASAP
wht01ranger's avatar
wht01ranger
check for a loose or disc. ground
wht01ranger
should be back there somewhere
tha mazda's avatar
tha mazda
the brakelights dont work on either side... this happened after I hooked up a set of trailer lights to the plugs whenever i took off the bed
tooleyhc's avatar
tooleyhc
Maybe a wire got pinched when you put the bed back on?
dssur's avatar
dssur
they dont work with your trailer lights? Because in order to use single bulb trailer lights on a mazda you need a logic converter, mazdas are two bulb systems.
Or they worked with your trailer lights and now they dont with your stock lights? Like someone suggested, you should check to make certain you grounded the taillights when you put the bed back on.
tha mazda's avatar
tha mazda
ok i got them working, but now i dont know how to wire up my LED strips
dssur's avatar
dssur
you need the logic connector I was talking about. Think of the LED's as single bulb brake/turns, the mazda is stillwired as dual bulb (sperate bulbs for brake and turn) so you need the adapter.
Some LED companies sell them along with their led's, I got mine at the parts store, I needed two and they were $18 each. You'll need an elctronicflasher too to keep the turns from going nuts.
tha mazda's avatar
tha mazda
were can i get sothing like that?
dssur's avatar
dssur
were can i get something like that?
I got mine at advance auto parts. Tell the guy you need the electronic adapter for dual wire tails to single wire tails on a trailer or just hunt around in the trailer section. The electronic flaser will be there too.
