do any of yall use or recomend using hydralic hose for bags it holds like 4000 psi i wanted to switch from airline to hydraulic line
olskoolpup
a lot of people use it. dont see where there would be and issue, besides it can get a little pricey.
SIKaltima
i have it on my truck...no problems on it!
kotalaynframe
thanks ima doin it this weekend i found sum at this store by my house it like 15$ for 6 feet they have shorter lines too
Low_SST
just check the id, sometimes its narrower.
I
ixenn
the hose isn't all that bad of a price its the fittings and getting the fittings put on thats going to get the cost up
kotalaynframe
the id is bout the same as a normal 1/2 inch line and they have normal pipe fitting at the end so they will screw right in to my valve and bag
maz duh
I had it on my truck and it worked great. I had a combination of NPT and JIC fittings and it worked great. I also built manifolds for my valves using service T's . My setup worked great for me, it had virtualy no leakdown either. Careful planning will keep the number of fittings needed to a minimum which helps lower the cost and the setup disassembles easily if necessary.
sweeden
stay with the regular air line!
cruisinlowS10
hydro hose isnt going to go around corners that easily.
