Is there anything that I am forgetting? Do I need anything to help with the alligning of the wheels?
bodydropped85
yup ur gona need an alignment. prob need to get some 2 degree camber eccentric bushigns and put them in your self and save the time and labor at the alignment shop.
N
Neverhear
Forgive my ignorance but can 2 degree camber eccentric bushings be found at any regular shop that does alignments?
bodydropped85
yup but they will charge you to put em in...
kaoss
what about tools? I tend to always forget a tie rod end spliter.
bodydropped85
yea u definatly wana soak all the bolts w/ some penetrating oil a couple hours b4 u start. also ull need a 1 1/8 socket for the radius arm and spring nuts, a big pry bar,and what ever size the jam bolt on the upper balljoint and lower ball joint nut is.just remember jackstands are your friends!
