I need one ASAP
matchead88@hotmail.com's avatar
I need one ASAP
matchead88's avatar
matchead88
Hey guys, i am in desperate need of a GCSMC 1/2" valve. Mine is stuck and it is not working, i already tried some 40-WD to loosen it and it seems like i need a new valve. So if anyone has one or knows of someone that sells them cheap, let me know, it could be used as long as it works. I need it asap because its for my daily driver. Thanks
Low_SST's avatar
Low_SST
wd40 prolly killed it
wht01ranger's avatar
wht01ranger
not to be a smartass, but are you positive the solenoid went out? could just be a bad connection somewhere
rockerdranger88's avatar
rockerdranger88
i agree with marky up there... look for other things that could be wrong with it bad connection could be it mang
whynotfab's avatar
whynotfab
Is it stuck open or closed?
purpl7duece
WHat's the proper way of cleaning the valve
matchead88's avatar
matchead88
Ok here is the deal, i was outside checking it and the connections are ok. What it does is that i hit the back down switch and both bags lower but then the drivers side bag airs up automatically on its own without me lifting it. What else could it be?
KRamseyKustomz's avatar
KRamseyKustomz
wire could be grounded
Iownissan's avatar
Iownissan
check all your wiring to make sure its not getting power when its not suppose to. if the wiring is fine, get a big wrench and give it a swift tap...
whynotfab's avatar
whynotfab
Hey Edgar, I got your message and sent you a Private Message, let me know when you get it
