SFBD what are you guys using for body mounts?
smallz
Hey whats are you guys using as ur body mounts when you did a stock floor bodydrop? Did you use stocks? or make your own?
thesource161
stocks! just trimmed a little
one_lo_one
Depends on if you can salvage the stock ones or not. If not just go to a sheetmetal shop and have a set made from 3/16-1/4" plate. It all depends on how much room you have.
mindlissmetalfab's avatar
mindlissmetalfab
i drew mine up in CAd and had them laser cut from 3/16. i think theres a pic in my profile.
Forever Draggin's avatar
Forever Draggin
i used the stock ones on the front and made the ones for the rear, 99 f-150 tho
AVTekk's avatar
AVTekk
do you mean the bushings or the steel mounts on the frame? i use the stock bushings but cut them down a bit and get a shorter bolt. I also use the stock mounts on the frame and they are cut, trimmed, and moved lower.
DawgsledMazda's avatar
DawgsledMazda
Energy Suspension makes a short universal body mount thats made of polyurethane. they are about 15 bucks each. email me for pics
4uh8rs's avatar
4uh8rs
I USED STOCK ONES ON MINE
roboblazer's avatar
roboblazer
i used the bushings that SD sales for four links and came off frame w 1.5 tubing
