hard lines?
14 following
hard lines?
draggindak avatar
draggindak
looking to upgrade from the rubber lines to hard lines for my air and was wondering if anyone knew where i could get some. i was thinking stainless steel, and im looking to run 1/2, i dont know what size that is for hard lines. also the fittings as well? im in the chesapeake, va area, so if anyone knows of any stores around that area where i could pick it up, or even somewhere off the internet would be great. thanks.
eks10BDRG-N avatar
eks10BDRG-N
copper type L and fittings from ekstensive.com. down here 60ft for 45.00 .
whynotfab avatar
whynotfab
Damn I wanted to check it out too..
Bandwidth Limit Exceeded
The server is temporarily unable to service your request due to the site owner reaching his/her bandwidth limit. Please try again later.
Apache/1.3.33 Server at www.ekstensive.com Port 80
JOEWEE avatar
JOEWEE
EXSTENSIVE HAS THE BEST FITTINGS FOR COPPER LINES!!
lownoma99 avatar
lownoma99
the hard braided lines are kinda expensive. i use high pressure line, like u use on a water heater. this stuff is sweet...its bendable, cheap, high PSI, and sounds cool as hell when u run air thru it. 1/2" line is big inner diameter(big enough that i can slide 1/2" plastic line into it) and u will need special fittings. They are usually between 5-7 bucks and u need to get them from a specialty dealer. i got my line and fittings from a local shop. hit me up if u want the number. good luck man
draggindually avatar
draggindually
i know that silver star customs in MS uses copper line with Legris fittings, the LF3800 if i'm not mistaken.
gravity5 avatar
gravity5
I used copper too....has worked fine, totally fine, and I used DOT airbrake copper fittings.....greenline ones I think
CLNSHVNnDRAGGN avatar
CLNSHVNnDRAGGN
I always used the copper line you can get at home depot or lowe's with the all nickel push fittings and never had any problems.
eks10BDRG-N avatar
eks10BDRG-N
yea thats the same one im talking about too.
LowRangerMS avatar
LowRangerMS
I run cooper also, you just have to get good bends and make them right, and make sure the end that goes into the fitting is perfectly round, or it won't seal. Also check for any spots it may rub against anything metal, cooper is a soft metal and you can rub holes in it.
You also need Plastic Legris push lock fittings for hard lines. The metal push lock fittings are for soft plastic lines.
Actually I'm thinking of changing over to all plastic DOT line......but I don't know yet......
