tacoma front suspension???
11 following
1989dangeroustoy avatar
1989dangeroustoy
do you use cups in the front or what,can you show some pics?
jetts avatar
jetts
I dont have any pictures, but you use cups.
Order the bolt on tacoma cups from cando
www.candospecialties.com
1989dangeroustoy
are they 100% bolt on or do you have to do some welding?
jetts avatar
jetts
the bottom bracket is bolt on and the cup part i just tacked in.
1989dangeroustoy
can anyone post some pics?
bdroppeddak avatar
bdroppeddak
its better to cut that spring pocket off and use a universal torsion bracket setup www.gravity-werx.com
hopsing avatar
hopsing
I agree, use a universal style upper mount then you can put a 2600lb bag in if you set it up right. plus it looks better
time1 avatar
time1
here is one i did. no bolt on crap here, i didnt even buy pre made brackets. i cut it all out of plate steel.
chumpchange avatar
chumpchange
these are the first set can-do came out with when steve first opened up. i had to cut the bottom one apart to work with the flipped lower ball joints but these are not bolt in mounts. fully welded and come with the shock tower reinforcements. make sure and use them. cups work awesome keep everything aligned perfect and in my opinion better then the "universal" torsion style.
1989dangeroustoy
i used universal tortions on my 89. i ran into alot of problems so i want to do something simple with my new truck thats why i want bolt in, im either going with an s10 or tacoma
