i am looking to pick up some drop spindles and i was wondering what brand were the best abd where i could find them. thanks.
i_love_primer
im not a hundred percent sure but i believe aim is the only company that actully carries these. correct me if im wrong guys, ive also been told they push the wheel outwards an inch
dragginmazda86
AIM is the only company that has them.I have AIM spindles they do push out the wheel a little but my escalades dont hit my 2wd fenders.
sadisticiron
you dont need spindles to bag it up to an 18 w/35 series plus spindles decrease lift height
gryte_racing
you don't even need spindles to lay out on 20's with a mazda is just alot of cutting and rework with balljoint angles
DawgsledMazda
the spindle doesnt decrease lift. the placement of the lifting device does. in this case a bag, if the bag is completely deflated when layed out and is the same distance from the pivot point as the stock spindles, there will be no decrease in lift.
if the bag is placed closer in you gain lift, if the bag is farther out you lose lift. a properly designed setup will allow the frame to lay and have more hight at full lift than stock height.
BYC arms accomplish this by the way. and also eliminate the strut rods and provide a bag mount and new balljoints and bushings.
also Toyota spindles can be used to get the 5 lug pattern.
mightymazda
I have a set for sale. They are brand new but have been mounted for fit. n_cichos@Hotmail.com
