s10 350 conversion
W
s10 350 conversion
W
wizard8575
I have a 95 gmc sonoma extended cab that had a 4.3 v6 im installing a 350 with a 700r4 tranny. I bought my mounts from s10v8.com the uppers and lowers. The problem I am having is the oil pan of the engine is hitting the frame and the trannys oil pan is hitting the cross member so the engine has to go back the tranny needs to go forward. Did I miss something else I had to do?
mindlissmetalfab's avatar
mindlissmetalfab
just move the engine and trans how they need to be so the engine clears the crossmember and modify or build a new trans crossmember to work.
