s10 on 20s
s10 on 20s
layframe318
i got an s10 how can i cut the inner wall of my bed without making it weak and also can you get bye without tubing your fire wall if you run small enough tires on it also where the best place to rewire the fuse box or what to do with it i need help with these problems get back to me someone
TC29720
You can cut the inside of the bed out without weakening it too much, but I would recommend putting some tubs back in there to add some strength back to it, you're gonna have to tub it either way with 20's, theres no way around it. And you can move the fuse box to the core support or just make a bracket to move it to the side
mtm's avatar
mtm
i have been told that with my 19s i will have to tub the firewall and i have 235/35 tires. I have always been told that tubbing isnt necessary until you get over a 20" wheel but i evidently its not until you get over an 18" wheel. What size are you running? When you say fuse box i assume you mean under the hood, if so move it to the inside your dash so its out of the way and cleans up the engine bay. As far as cutting the inner wall of your bed, use some steel tubing to fabricate a support frame to hold it all together. Why are you cutting out the inner walls? Is it for a sheet metal bed or do you just mean to cut it out for the back wheels to protrude
layframe318
it the side closes to the front side of the rim i hit that as i try to lay out the truck already painted and not sure if i weld right their if its going to heat the paint up to much yea thats what i was thinking about the fuse box is mounting it by my cor support cause thats where i put my computer at and it worked good so far
layframe318
runing 225 35 20
