wireing for witches
wireing for witches
rrider2005 avatar
rrider2005
i just need to know which wire goes to the relay on which wire goes to the switch. (86 & 87) i know 30 is 12v+ and 85 is a ground. i went to bagginit but that was no help.
lower avatar
lower
why would you want to wire a witch?
Bodydropedon22s avatar
Bodydropedon22s
Maybe he is building a haunted house.
Bodydropedon22s
OR is like wireing for dummies but just for witches.
DawgsledMazda avatar
DawgsledMazda
do you mean wiring for switches? suicidedoors.com has a wiring diagram for switch boxes. but it sounds like you actually need to know the wiring for relays. email bdpathfinder@charter.net thats wormtronics and the guys name is sherman. hes a wiring guru.
whynotfab avatar
whynotfab
See where the 12v goes to the pressure switch, instead of a pressure switch you use your toggle switch.. then to 86. Hope that helps.
