Engine ?:Ford 2.3 in B2200?
thalwr1 avatar
thalwr1
I have an 87 B2200 5spd 4cyl..I also have an 88 t-bird turbo coupe..5spd..Curious to know if the engine/trans from the t-bird will "Bolt-in" the B2200..minus the wiring issues of corse..lmk asap thanks guys!
DodgeRT avatar
DodgeRT
try it out and see,if they can put a s2000 motor in a b series,it should work.maybe a little thinking and engineering,but that would be sweet if you got it to work though
BIGRIGZ avatar
BIGRIGZ
Alot of times like these you can call the local salvage yard and give 'em the info for the one car and ask them for interchangeablity. They have a computer program that will tell them all the parts that can work together.
thalwr1 avatar
thalwr1
Well..hers the dilema..lol they both run perfectly only taking em apart if im positive it'll work ya'know..
bodydropped85 avatar
bodydropped85
hmm it would be close, but probably not bolt in.
karathos avatar
karathos
No go, Not a direct bolt in. Will bolt into a Ranger. Not a mazda..Look into the probe engine.
dssur avatar
dssur
send me your email address, I have a video of a truck in Fla that did this swap, looks pretty wicked fast. He built new motor mounts and used the ford tranny (new mount there obviously, as well as modifying the driveshaft), stock rearend etc. Sawpped over the ECU etc. He had a webpage up but I dont have the link, maybe someone else does?
thalwr1 avatar
thalwr1
Hey russd its thalwr1@aol.com I rode out to the acro meeting with u a while back..Im just gettin back in the scene I built my ranger right after all taht then went back to hondas..lol
dssur avatar
dssur
its to big for an aol address. do you have a gmail address? Or does some one want to host it?
And you are thinking of the acro Russ D, he is screen name rrussd on ssm. I live in the midwest.
krazeryn avatar
krazeryn
No, not even close to "bolting in"....Check my profile....I have a turbo Mazda Mx-6 motor in my Mazda. It is mostly a "bolt in" but lots of other work required to make it work.
