Hi. I just got my engine back in after a new crank, bearings, and head. Now that it's back in and runs, my oil pressure light is on. I pulled the o/p switch and turned the engine over. Pumped oil out. Also tried a new switch. Still have a light. What now? Is there another way to check if I actually do have oil pressure? Thanks.
OldSkoolCadillac
screw a oil pressure tester in and see what kinda pressure it is running at
N
NotFastEnuff
Where would I get one? I looked at Autozone. I thought someone made something like that, but they only had fuel pressure and compression testers. Thanks
bodydropped85
thats y i put a manual oil pressure gauge on my truck...
jmn444
Just get a guage w/ a sender and hook it up, they should have em at autozone or summit or any speed shop...
this was on autozones web site:
Autometer Autogage Series 1-1/2" Electric Oil Pressure Gauge
Auto Gage Gauges; Black Instrument Face With White Readout, White Needle, Black Bezel
0 - 100 PSI
1/8" NPT Electric Sender
1/4" NPT Adapter Fitting
Electric Gauge
Looking for a superior set of instruments at an affordable price? Stick with performance you can trust! Auto Gage instruments are the perfect choice for street entusiasts on a budget! This line is well known for its large selection of tachometers, gauges, and custom under dash gauge panels for a wide variety of street application. Auto Gage instruments have a unique race inspired design and are built to the same high standard as Auto Meter's high performance instrument lines.
Part No.: 2354
Weight: 0.72 LB
Price: $41.99
Something like that will for sure tell you if you have a problem or not.
