Valve ?s
Valve ?s
jasrw
what are manual valve's what do u have to do different than electric valves?
bdroppeddak's avatar
bdroppeddak
you have to manually open the valve with a lever, kinda like a water faucet.
olskoolpup
unless they are MIC manual valves. those are basically toggle switches. but you have to run airlines into the cab to the back of the valves.
major differences, money, install and speed of the system.
jasrw
there are switches in the truck.
forbidden's avatar
forbidden
If your thinkin of doin manual valves dont... you will be so mad tht you did. plus they are slow as hell..
jasrw
is it hard to change the valves to electric valves?
forbidden's avatar
forbidden
you mean to change the manual ones over to electric??
Want to save money on Air Ride, Hydro's and much more?? Check us out!! Parts added everyday
jasrw
yea that is what i mean
forbidden's avatar
forbidden
i think it would be better just to have electric ones to begin with. I dont thinl you can make the manual ones switch to elect..
cdndragrr
manual valves suck in my opinion i had them on my truck and hated it slow as hell u need a ton of fitting and check valves plus u have to drill holes into your cab it just sucks all around plus electric valves arnt that expensive anymore
