DOT Fittings Question
ricky@whynotfab.com's avatar
whynotfab's avatar
whynotfab
When I need to take off an airline, and then reuse the fitting, with a Parker DOT fitting will the ring part be re-usable or will I have to buy another? Ive changed lines alot with ace/lowes cheap fittings and had to have spare rings/inserts.. but these Parker fittings, the Insert is built into the fitting and the ring has a small ring around itself im guessing to seal more properly. anyone know?
bodydropped85's avatar
bodydropped85
u should be able to reuse it
