engine swaps
engine swaps
Lowrthnu84pup
does anyone have a clue on how to convert a fuel injected nissan 2.4 liter to be carburated and if that engine would fit in an 84'isuzu pup
john trevino's avatar
john trevino
how about motor mounts or adaptor to stuff a 350 in a 94 pup.
BK2LIFE's avatar
BK2LIFE
convert a fuel injected motor to carb? why in the world would you ever want to do that? just make the FI work, its not hard..
and make your own motor mounts, some 3/8 steel and a welder...
papaburgandy
alot of people convert from fuel injection to carb, some might do it b/c they dont have the ecu which alone can be $1500 bucks,others do it b/c plumbing and all electrical is alot easier. its so popular that edelbrock makes an intake for the Ls-1 motors in vettes to do this very thing. mainly for the hotrod scene and our scene. if you want to drop a small block in a late model truck it is alot easier doing it with a carb setup.
CustomParts's avatar
CustomParts
I got them!!
papaburgandy
dont know much about the nissan 2.4 motors, but see if you can find an older motor which might have been carbd, if you get lucky might be the same block used if so just grab the intake manifold and carb, and check to see if the heads have the same pattern, it might bolt right up, with little mod.
