F.B.I- L.E.D question
begfomurrcy@yahoo.com's avatar
suckafree's avatar
suckafree
I got some 14'' L.E.D's from FBI Mini and I am finally wiring everything up. Everything works fine, got brake lights, running lights, blinkers.Here's the head scratcherwhen I have the running lights on and turn on the blinker it just lights up.Their little directions say, if it blinks fast or stays on wire in a 5 watt rezister. So does that mean wire that in if it always does it, or will it fix my problem?
corey0814's avatar
corey0814
if you're using the TAC units, then no it won't. i got those a while back but the resistance wasn't right so i went with the 10" 's. then everything was right.
framescr8pintoy's avatar
framescr8pintoy
the led's arent pulling as much power as a regular light bulb does so thats why the led is staying on constantly. if you wire in that resistor itll pull enough i guess amperage on the circuit allowing the led to flash properly. it might flash faster than a regular bulb did before. mine were doing that too. i just wired up an extra lightbulb/socket and hid it where it would be outta sight. works fine for me.
9
95sonomax
Either wire in a resistor or if it is for your blazwer get a digital relay for the blinkers. You can buy them at autozone, etc.
