Custom bag brackets (front)
11 following
grounded2200 avatar
grounded2200
anyone know who makes bolt in suspension for the front of a b2200. i need to redo my setup and id like some nice mandrel bent pieces. any info (websites, pics, co.names, phone #'s) will be greatly appreciated!
Chris
Wicked Fantacies avatar
Wicked Fantacies
im sure BYC can make u somethin not sure if he already does or not.
dragwithme avatar
dragwithme
try air ride tech
hopsing avatar
hopsing
Are you talking about the control arms or the brackets? If the brackets, you arent going to find any mandrel bent pieces for that, and probably not bolt on either. All the good bracket kits are a weld on. If you are looking for arms, BYC (builtbybyc.com) makes excellent arms that are made from thick wall DOM tubing (still not mandrel bent, nobody does that I know of) Hope this info helps.
dssur avatar
dssur
bolt in bag brackets on a mazda would be too far out on the control arm, no lift and EVERYTHING would hit. You NEED to cut a little. After that, universal mounts weld in just fine.
Wicked Fantacies
u can always count on Russ
hopsing avatar
hopsing
^^ what Russ said.
dssur avatar
dssur
thanks guys, but Mike White will be on here in no time telling me what an idiot I am and how his control arms cure cancer.
Ih8bmps avatar
Ih8bmps
The only place I know you can get bolt in bag crap o'la is from a.i.m.( www.airbagit.com )
livinlow avatar
livinlow
^^ buddy of mine has thoe shAIM brackets and the bolts snapped,so he welded them in,half decent design i must say,If you plan on buying them,go out and get some good grade 8 hardware,aim supplies you with grade 5 and they SUCK.Peace!
