99 ranger control arms
JFcustoms avatar
JFcustoms
does anybody lke byc or whoever have a set of control arms ready to go lay a ranger out without problems, camber fix....will the djms solve all the problems or what.
DawgsledMazda avatar
DawgsledMazda
BYC does, adjustable uppers and lowers for bags. mike@builtbybyc.com
rockeredranger avatar
rockeredranger
mike, how much does a set of those cost for the uppers and the lowers?
DawgsledMazda
upper set is 230 shipped and lower set is 270 shipped.
upper and lower set together shipped is 490.
JFcustoms avatar
JFcustoms
ouch, ok f that im gonna just build a new frame and re angle the top arms then i can lay full frame not front clip then roll pan and spend 500 doing that...ill make a bitchin frame for less than 500
butter428 avatar
butter428
if you think you can make a full frame, then why not make your own control arms?
DawgsledMazda
check the price of the new balljoints and find out how much they cost, remember those are with new balljoints and poly bushings and are adjustable. the price will likely go up very soon. go ahead and make some. laser cut balljoint plates, balljoints and 1/4" thick DOM tube aint cheap, then add in making the adjustable ends and new balljoints.
GOOD CUSTOM WORK IS NOT CHEAP, AND CHEAP CUSTOM WORK IS NOT GOOD.
JFcustoms avatar
JFcustoms
well if i buy these bastards then i still have to z my front clip to lay the frame, piece of shit ford rangers....so can you put up pictures of the arms installed so i can be convinced that it will take care of my problems or will i still have bad negative camber and balljoints breaking cause the top arms are too short..please post pics
JFcustoms avatar
JFcustoms
and i also need a measurement for the standard cab short bed its the 1" hole on the side of the frame under the cab by the gas tank crossmember to the center of the axle...thanks for the help
DawgsledMazda
i think im gonna sell these without balljoints so I can sell them cheaper. they will fit the stock balljoints. they have adjustable upper ends so they work with or without a Zd frame. the lowers are shorter by 1/2" for better wheel clearance.
pics on the site as fast as I can get the web guy to put them up.
