Possible to lay frame on a 4wd truck?
Spart
I'm kicking around ideas on bagging a Syclone and wondering what all would have to be done to actually lay on it while still maintaining the 4wd.
jcordova's avatar
jcordova
Edited: 9/1/2006 9:03:02 AM by jcordova
jcordova's avatar
jcordova
lo75lux's avatar
lo75lux
my friend had a 4wd 10 that layed..the old owner is on here i think....slammed94sdime
blazedout84's avatar
blazedout84
i dont remember what shop built it but wasnt that 2 dr excursion 4wd. im pretty sure it was and it layed body
bodydropped85's avatar
bodydropped85
that was totally polished, and it wasnt 4wd. they used FSC front suspension.
TwistedPhil's avatar
TwistedPhil
Anything can be done, given enough money and work, but you should think about what makes sense. The upper balljoints won't last if you bag it over the upper arm, it won't ride as nice, and you'll likely have issues with the front drive axles.
You'd probably end up happier in the long run if you just clipped it with a 2wd setup with drop spindles and a nice set of control arms. Plus, then you could drift the truck with that much horsepower running to the rear tires!
Good luck either way you go- Cyclones and Typhoons are sick!
-Phil at FBI
