Air Ride Suspensions \  Air line fittings?
Air line fittings?
Air Ride Suspensions Q & A
views 1161
replies 8
following 7
48rob   +1y
Are the push on plastic air line fittings really good, or am I better off using brass with an insert and ferrule?
Replacing plastic fittings down the road is not on my want to do list...
Rob
jhouk2000   +1y
I have used these fittings and I have no complaints. (link below) I used the plastic fittings on my first truck and I was constantly chasing leaks. On the next truck I used compression fittings like you described and while they never leaked they were more time consuming to assemble right.
http://www.newmaticsinc.com/category_s/227.htm
48rob   +1y
Thanks.
So you're suggesting push on fittings are okay, just use metal not plastic?
Rob
jeebus @ mmw   +1y
ive used pretty much every range of fitting these guys offer at www.airridefittings.com and i like them all. Plus, they ship very fast!
Taylor
truck action   +1y
Push to connect brass fittings,no problems with! :BEERCHUG:
48rob   +1y
Thanks!
Rob
i8nt2lo   +1y
Brass with the inserts are the way to go. I've never had leaks with those, ever.
AON-JAMES   +1y
I too use airridefittings.com, and my entire car for the most part is plastic PTC fittings, I daily drive it with zero leaks. I've left it up for 3-4 days, with out losing any pressure.
okcustoms   +1y
Nickle platted PTC all the way, never have any leaks or line blow outs.
