Air Ride Suspensions \  Bagging a camaro
Bagging a camaro
Air Ride Suspensions Q & A
views 635
replies 5
following 5
darkstar06   +1y
Ok,i looking to bag a 2010 camaro ro lay on 20s. What all is involved and has anyone done one. Love to see some pics of the set up.
utibaggedtruck88   +1y
Im not sure about on bags...there have been a few done...there was project "Red rum" and Perfect Poise out of Arizona has a teal one on juice, its a hydroholics build...its pretty sick
THE_CRUCK   +1y
Red Rum was bagged if I remember correctly, also with a axle swap instead of IRS. There was also the one built by Just Plain trick in Arizona that nearly laid on 22's, but was juiced as well as the blue one.
Hey Cruck, was that the charcoal grey one on the KMC Rockstars?
tre5   +1y
Errrr. wrong. Red Rum does not have a straight axle swap. It has the factory rear clip, but the factory arms have been narrowed. The axles also were either narrowed or replaced with shorter ones.
The blue one in Perfect Poise was originally bagged. I pulled the Air Ride Technologies kit out due to issues with the ride and the kit itself. The front end made a loud popping noise when it lifted.
Laying on 20's should be easy depending on the tires you go with. The blue camaro I did has a pretty wide rear wheel/ tire combo (22X12 rear I believe) and the tire contacts the inside of the wheel well before the top. If you run a narrow wheel/ tire and a small sidewall, you should have no problems sitting low... with hydraulics. With the bag kit it didn't sit as low as the hydraulics. Also, if you do hydraulics you can adjust for the tire size you are running with the threaded cylinders available from www.Hydroholics.net Let me know if you decide to go that route and if you need help with anything.
darkstar06   +1y
Thanks
