GuiltyByDesign.Net- Air ride supplies and CNC bracketry
29 following
kyle@guiltybydesign.net's avatar
guiltybydesign's avatar
guiltybydesign
We carry a full line of air ride supplies from top companies but i pride myself in our line of bracketry. All of my bracketry is CNC lazer cut from Pickled&Oiled steel, this steel is of a higher quality and has already had surface impuritys and contaminants removed and has virtualy no millscale. This means less metal prep time for you and cleaner welds! Our lazer has capabilities of anything up to 1/2'' mild steel and 3/8'' alum or stainless.
Heres a look at some of my line of axle tabs, gussets, bag plates, and frame mounts.
And heres an item im rather proud of. This baby welds to a crossmember you have on the ground and locates all 4 front 4 link mounts. The beauty behind this bracket is its designed to work with my axle tabs to space all the pivot points equally and its modular insert adds considerable strength to the top mounting locations. That keeps your 4 link working properly and saves you time setting everything up. Simply tack weld the inserts countersunk legs into the tab holes and grind smooth for a seamless look. The bracket keeps the bottom bushing 1/4'' off the ground, feature a flatspot 1/4'' from the edge of the rail so you can wrap your weld around the end. It also features a full shoulder surrounding the polyurethane bushing just like all my tabs. Other tabs dont cover the entire bushing and that could lead to the tab cutting into the bushing or causing premature wear. Hell it just looks better too!.
Ill be developing more modular designs like this soon. Check out the site for our full lineup and compare prices. Ill be bumping the thread as soon as i get more parts in the next few days.
A few of you already have some of my parts on your ride, lets see what you did with them.
http://guiltybydesign.net/?category=Bracketry
guiltybydesign
Showin some dually love with these 4'' axle tabs. I also got my diamond shear load plates in today
phat phabrikationz's avatar
phat phabrikationz
I still rock mine!!!  Chrome plated of course!
MaDeNMiAmi305's avatar
MaDeNMiAmi305
good shit. ill keep you guys in mind as i start my build.
baggedblazer350
can you make any scorpion stuff like maybe a hood prop or a bridge gap decoration/ad on or something like that?
guiltybydesign
Anything you need, email me Kyle@guiltybydesign.net
laidoutcourier's avatar
laidoutcourier
great parts and the the sweetest alumunum bar end bushings  no need to take the bushings to weld them up
laidoutcourier
guiltybydesign
A couple of new items today! First is an 8pc mazda specific notch kit. These notches mate up to the mazda framerails perfectly and allow you to lay frame on a 255/35/20.Second is a universal 8pc octagnal notch kit. For those of you who want a little more shape than the boring standard notch kits. Both are lazer cut from 3/16'' P&O mild steel and are in stock now. Ill have them available at my booth this weekend at Slamily Reunion. http://guiltybydesign.net/?category=Bracketry&subcategory=Notches
guiltybydesign
Just got my keychains in!http://guiltybydesign.net/?category=Swag
