hydroholics one pump 5 dump question
pmiller avatar
pmiller
I like this setup.  Can any one explain more about this and how it works?  I mean explaining the flow.  I thought I read somewhere where this setup can stand 3.
Uncle Fester avatar
Uncle Fester
Feel free to PM AON-4PumpedCL he will be able to help.They sure look nice in person, I would like to use them myself once I get wife a project.
AON-OFFDAHOOK avatar
AON-OFFDAHOOK
If you haven't been, check out www.hydroholics.net manifolds section.   Basically, when the pump gets activated fluid gets sent to all four corners and depending what you're looking to lift, you activate the dumps that will NOT build pressure therefore the fluid's path of least resistance is to fill (and lift) those opposite corners.  The 5th dump is opened (along with the pressurized dumps) to redirect the fluid back into the pump reservoir.   Standing three wheel will depend on the vehicle, weight placement, cylinder size, and which switches you have wired to allow the three wheel function.   If you have any questions, feel free to hit me up: derek@hydroholics.net
