87 s-10
87 s-10
LndRanger86 avatar
LndRanger86
whats up guys? i just scored an 87 s-10 . i have the bags in the mail but i plan to bodydrop it only to the pinch. I am gonna run a 17-18 all the way > just a nice old school ride to cruise around.What are some tips on this truck when bodydropping it? i don't need ac but i want defrost. Are there any aftermarket heat units i can run to have this or modify the factory? Also i want to take the 2.8 out of it and put a small block of some sort in there. Whats a good easy motor i can put in it, without header issues? thanks
nevr2los10 avatar
nevr2los10
does that 2.8 run?? ill buy it off of you if it does.  I hate to do forum referrals but if you get on www.s10forum.com you will find all of the info you need already explained in heavy detail on how to do whatever you want to your s10
LndRanger86 avatar
LndRanger86
thanks. it does run. pretty good too. no smoke. if i get a small block here shortly i'll hit you up.how much are you looking to spend.i'm really flexible.by the way i already found s10 forum but i was having trouble logging in so i went elswhere.
LndRanger86 avatar
LndRanger86
ALSO. WILL A 350 FIT UNDER THE HOOD ON THIS THING. I'VE SEEN WHERE A 2.8 IS HIGHER AND WILL MAKE THE 350 SIT HIGH AS WELL.IS THAT FACT OR FICTION?THANKS
boooghar avatar
boooghar
Edited: 2/1/2009 9:33:53 PM by BOOOGHAR
check out http://www.V8S10.org
