1st gen s-10 door
1st gen s-10 door
superstan avatar
superstan
I need a first gen s-10 door bad. mine is sagging and I have replaced the door pins and bearings. Id like to have a good door. im in NWI so if anyone has one plz let me know. also what should i expect to pay for having rocker panels and cab corners installed with me buying the parts?
injunjoe avatar
injunjoe
hey bud check www.car-part.com they are typically linked up with all the salvage yards in the area you chose and will have a price description etc, hope this helps joe brownsville
solows10 avatar
solows10
which side i live in the sw area of michigan
locaddy avatar
locaddy
How bad is the door sagging? Ive fixed alot of those and havent come across one yet that couldnt be fixed w/ a block of 2x4 wood. Just a suggestion before you buy a door, stick a 2x4 in the jam below the bottom hinge and shut the door against it and put a lil pressure on it. Do that and check it a few times putting a lil more pressure each time. That door should raise up. Be careful if you try it, you could do more damage than good if you get crazy with it.
superstan avatar
superstan
its the driver side door. how fare away do u live. its so bad that i can put near bearings and pins in today and they would still sag. the holes in the hinges are just to big from years of wear. im the 3rd owner and funny thing is the interior is great expect where the seat is tore because my big but sliding across it. they just never took care of the out side. it has rust on it and missing seals around the glass and the interior panel came off. thanks for the help.
solows10 avatar
solows10
im in benton harbor about 40 miles from the state line on I94
