air management system (reply about spelling) thats u guys have sad sad
jjboy avatar
jjboy
Edited: 12/9/2008 2:12:47 AM by jjboy
ask for a little help all i got was shit about a mis type one trying to sell and i must thank the one that tryed to help :wtf:
wrkd94toy avatar
wrkd94toy
wtf is f.t.r.s.s
standardbyker88 avatar
standardbyker88
front teeter rear side to side ?
travis98s10 avatar
travis98s10
I guess he meant fbss. Either way you will need 8 valves to be able to adjust all 4 corners (fill and dump per bag). You will spend a little less on fittings if you use 1/2" valves and 1/2" line. SMC's are fairly cheap and reliable. If you want to stay on a budget I would only use 1 7 gallon tank for now because you will need 2 compressors to keep 2 7gal tanks filled. You will need a pressure switch on the tank to turn the compressors off automatically at a set psi. And of course some momentary switches to control the valves. That should get you the basics. Get some gauges if you have any money left over.
jjboy avatar
jjboy
Originally posted by wrkd94toy
wtf is f.t.r.s.s
thanks your so much help i was hopping this site wasnt like a lot of oters LOOKS LIKE MY BAD
twiztedb22 avatar
twiztedb22
what oter site u talking about
twiztedb22 avatar
twiztedb22
fatboysS1O avatar
fatboysS1O
fbss = 8 valves. i recommend asco valves.
youll need compressors. how many is up to you. i recommend viair. or you could use a edc.
youve got tanks. id just go with 1 of those 7 gallon tanks.
youll need a switchbox of sorts. a rocker switch box, big ass 10 switch box, push button switches, paddle switches, just whatever u prefer. i recommend a rocker switch box.
just get u a 50' roll of 1/2" line to cover all ur mistakes since u seem to be new to all this.
when it comes to fittings id recommend ptc fittings. theyre easy and dummy friendly.(thats why i use them) when u get everything layed out like u want it then go back and look at ur setup and make u a fittings list. i could make u a common kit for a fbss setup but it never works out right. u always have to go back and get an extra fitting or so. so just make a list when ur ready.
u dont have to have a pressure switch but it kinda simplifies things. u can have a simple on/off switch for ur comps if u want.
if u do the on/off switch youll need atleast one gauge to check ur tank pressure letting u know when to turn on/off ur comps. some folks run gauges even with pressure switches. others run gauges to each bag so they can watch the psi in each bag. so...whatever u wanna do.
u said u need everything but bags.....take this time to go back and look at the bags that came with the truck and see if they are still any good. see if there cracking/splitting/or have been rubbed any. if so replace them and fix the area if they are being rubbed. also look over the entire suspension setup and make sure its safe/road worthy.
check out www.gravity-werx.com for everything listed above.
jjboy avatar
jjboy
thats your help you must have much to do to-day ----
TwistedMinis avatar
TwistedMinis
You aren't going to get an ounce of help with an attitude like that.
