Need help Baggin a Cadillac
11 following
hashit1972 avatar
hashit1972
What up dudes, I have experience baggin full size trucks, but i don't know much about how baggin Cadillacs, are they the same? I have a 64' cadillac coupe de ville and i'm planning to bag it. Need help with where to cut to lay body and do i c-notch the back or what? any advice would be sweet thanks. hashit.
sicsan avatar
sicsan
DAMN EASY CAR TO BAG. JUST CUPS UP FRONT. WANT NEED A NOTCH UNLESS YOUR RUNNING SOMETHING OVER 24 INCHES IN HEIGHT AT THE REAR. MAY NEED TO RAISE THE DRIVE TUNNE ABOUT A INCH OFF THE BACK. THE SHAFT HAS A BALANCER AND IT WILL RUB THE FLOOR IF YOU DONT. I LEARNED THE HARD WAY AND KNOCKED THE SHAFT OUT OF BALANCE ON MINE. RUN THE LINES THROUGH THE INSIDE. THERES NOT MUCH ROOM UNDERNEATH THE CAR DUE TO THE WAY THE FRAME IS AND EXAUSET. BUT FUCKING EASY AS HELL MAN. WERE YOU LOCATED??????
dailydraggn avatar
dailydraggn
any pictures?
sicsan avatar
sicsan
PICS WHY? NOT SOUNDING LIKE A DUMBASS. BUT LIKE ALL YOU NEED TO DO IS WELD A CIRCLE BRACKET ON THE LOWEWR CONTROL ARM. MAKE A CUP THEN THE FROTS DONE. BACK JUST CUT THE SPRING PERCH OFF TRAILING ARM AND FRAME AND WELD YOUR BRACKETS THERE. YOU CAN DO THESE CARS IN A WEEKEND EASY
dailydraggn avatar
dailydraggn
Just wanted to see the condition of the Caddy.. doesnt hurt to ask.. gezz.. btw i got my self a 70 sedan im about to bag as well...
automatik23 avatar
automatik23
is a 67/68 as easy?
blazerss avatar
blazerss
hell yea post some pics caddies are bad. yea you definately have to notch the rear of the driveshaft tunnel.............i wouldnt rush it in a weekend
sicsan avatar
sicsan
Originally posted by automatik23
is a 67/68 as easy?
same thing up front little different in rear. but still as easy
hell yea post some pics caddies are bad. yea you definately have to notch the rear of the driveshaft tunnel.............i wouldnt rush it in a weekend www.streetbeatcustoms.com
when youve done a few of them its pretty easy you dont rush because you already know what needs to be done. although on the 65 up youll need a huge driveshft tunnel made to to its a one ppiece driveshaft. also get it mandrel bent and not beated around a carport pole. youll be surprised what dumbasses do this. it just makes for a cleaner look........
hashit1972 avatar
hashit1972
Thanks for the baggin advice for my cadillac. I wish i knew how to post pics on this page, but i don't.
bagged300mondubs avatar
bagged300mondubs
i had to tunnel all the way to the output shaft on my 70 coupe deville... i just heated up some sheat metal and bent it on the stock springs that i tacked together, came out perfect!!
