Running stainless everything...need suggestions
thenephilm avatar
thenephilm
I plan on running stainless hardline for fuel, brakes, and air line but I'm not sure of the best and cheapest place to get the line and fittings. I know you can either get straight sections or coils but I heard the coils are a bitch to straighten. Any suggestions or tips on working or buying this stuff?
trenth48 avatar
trenth48
i would definitely get straight pieces! Don't know about the cheapest but at work we use Godman.
thenephilm avatar
thenephilm
i would think straight pieces would be easier to work worth but the coils are a lil cheaper..any suggestions on a bender and fittings?
ixenn avatar
ixenn
find a 4 wheel parts place or a fittings store they will have all the fittings and line you could want, they can also usually bend it for you. The nice benders for 3/8 and 1/2 are from 75 to 140 dollars so you might just have them bend it for you. I used all 304 Seamless ( has to be seamless!) for my lines and did the same thing your doing - it is expensive. I used all
AN fittings.
ExplicitDesignz avatar
ExplicitDesignz
Might wanna get a job in a plant too. Be able to get all the stainless fittings n line you can handle. lol
jeebus @ mmw avatar
jeebus @ mmw
deffinentally go with strait sections.
i got all my stuff from www.swagelok.com , they had a local store here, so i just picked it up locally.
you can check my build on my 94 S-10 for pics in my profile.
Its great stuff to use 5000psi strong, without flaring the ends!!
Taylor
