avs switch box install
brown708@yahoo.com's avatar
Nmud2Deep's avatar
Nmud2Deep
i was wondering if and how would i be able to install the new avs 7 switch box in place of the normal 10 switch box im running now...i know the gauge of the wire is different/larger coming from the valves then on the avs box...what all needs to be done..
Nmud2Deep's avatar
Nmud2Deep
anyone?
eyekandydesigns's avatar
eyekandydesigns
have you tried emailing someone at AVS or calling them? They are very helpful.
whynotfab's avatar
whynotfab
The boxes usually come with a small packet of quick connect terminals, male or female I forgot (one half being already on the end of the switchbox wires) then all you do is crimp the other half of the terminals onto your existing valve wiring, if the wire is too large you could pick up some matching terminals for a larger gauge of wire. Tons of wire connecting terminals available even locally, check the gauges or snip a small piece off your valve wiring and take the box with you and match it up..
AVS boxes kick ass btw
disfiguredS10's avatar
disfiguredS10
^^ yup, it's a pretty straight forward swap. I love my 7 sw. rocker box!
Nmud2Deep's avatar
Nmud2Deep
thanks i know the wires coming off my old 10 switch box are different colors than the new box
whynotfab's avatar
whynotfab
Edited: 6/16/2008 7:05:32 PM by WhyNotFab
10 Switchbox Wiring:Red - PowerGreen - Driver Front UpYellow/White - Driver Front DownBrown - Passenger Front UpYellow - Passenger Front DownGreen/White - Driver Rear UpBlue - Driver Rear DownWhite - Passenger Rear UpBlack - Passenger Rear Down
AVS Wiring:Pink - PowerWhite - Front Left UpYellow - Front Left DownOrange - Front Right UpRed - Front Right DownGrey - Remote DumpGreen - Rear Left UpBlue - Rear Left DownPurple - Rear Right UpBrown - Rear Right Down
974door's avatar
974door
I don't know if they are the same, but I am wiring a 9-switch box up in a truck for a friend, and it yakes 18 guage wire from the valves to the brain and it is also labeled on the brain it self to tell you which valve and direction to plug into it.
Nmud2Deep's avatar
Nmud2Deep
the seven switch box dosnt have the brain..straight to the valves
chevygurly's avatar
chevygurly
if you need more help email me kris@avsontheweb.com
