valves leakin
valves leakin
stopndrop avatar
stopndrop
hey guys im back for another question. my 1/2" blitz valve is leaking. i have it set up on my front raise valve and it leaks up when i turn my compressors on. my question is y would it do this? it was workin just fine then i started to do this yesterday.thanks
TwistedPhil avatar
TwistedPhil
With a diaphragm valve, usually the only reason you'd have a leak would be from dirt or other foreign matter keeping the diaphragm from sealing properly. With the truck aired out, and the tank empty, remove the 4 bolts that hold the two halves of the valve together, take out the rubber diaphragm and spring, and clean the heck out of everything. Check for any tears or damage to the rubber, and reassemble- no grease or oil necessary.
If this doesn't solve your problem, email me at phil@fbirides.com and I'll have you send that valve back for warranty replacement, since we handle the Blitzluft warranties directly.
Good luck!
-Phil at FBI
stopndrop avatar
stopndrop
alright man thanks!
