Flexible Braided Hose?
11 following
bbrownderville avatar
bbrownderville
I'm getting ready to run all my air line on my bagged frame and im having a delima. I dont want to run my plastic air line around my c notch so i want to run my air line through the notch since it is hollow. Would leader hose be good enough for this purpose and if so where can i get just the leader hoses for the least amount of dollar bills. Id like to get two like 2-3 feet long so that the fittings would be out of sight when installed. I'm trying to keep it kind of clean looking around the bridge and stuff. Any help or other suggestions would be appreciated.
lucky_brew avatar
lucky_brew
hard lines man! www.eastwood.com sells the bender and flaring tool
bbrownderville
i cant afford to get hard line. I'm on a tight college budget. Gas getting back and forth to school is using pretty much all my money. I love the look but i just want to get my truck put together lol.
junior avatar
junior
i wouldnt use braided hose unless u can secure it hella good...
bbrownderville
Yea i was thinking about the possibility of it rubbing through but i think it will be alright. if anything ill wrap the part that wont be seen up in the notch good with something.
junior avatar
junior
its gonna rub threw if there is any lil movement...on my big truck a bolt for a clamp backed off a lil the hose was able to move and u shoulda seen the nasty hole i ended up wit
bbrownderville
thats why i guess ill just use leader hose, I wont drive my truck too much, just to shows and at 20 bucks a pop, i can replace them fairly cheap. I see that suicide doors carries the viair leader hoses so ill just pick some of them up i guess.
fatboysS1O avatar
fatboysS1O
we sell steel braided airline if thats what your lookin for. it isnt cheap though.
LowOrange88 avatar
LowOrange88
soft line will feed through your notch, but as stated, it will move around and rub some, what you can do is depending on the size of the tubing, you can take an old air compressor shop hose, and cut a chunk of it, slice the length and wrap the tubing with that, and secure with zip ties, that stuff is pretty thick, so even if it does move a bit...be a long time before it chews threw that. Just an idea if your on a budget, cuz braided hoses arent cheap.
200bodydroppedrangr avatar
200bodydroppedrangr
Grommets man nice thick rubber to protect hole for the plastic line going in your frame and back out. and only set you back 50 cents each!!!
