fliped ball joints
fliped ball joints
fatman avatar
fatman
have a 95taco and ive been told to get my truck to layoutmore to flip my ball joints how do i tell if they are fliped yet and how do i do it if there not thanks
Tacon19s avatar
Tacon19s
Stock the lower ball joint is mounted under the lower arm, if they are already flipped they are on top of the lower arm. And to do it basically unbolt it and remount it on top of the lower arm. for specifics go to www.customtacos.com there is alot of help on flipping them thangs. If youre running anything bigger than an 18" it might not be a good idea to flip them as the bumpsteer is increased when you do this....good luck
fatman avatar
fatman
just went out and looked they are on top is there anything eals i can do thanks
Tacon19s avatar
Tacon19s
well you should be laying out on an 18" unless your bag bracets need to be moved up some...take the bags out and see if it will lay. if it does then its your bag placement(brackets need to be moved up). if not its your upper ball joint prob binding.
fatman avatar
fatman
what about dropspindale i see you have them how much do they run
Tacon19s avatar
Tacon19s
Edited: 2/5/2008 12:03:35 PM by Tacon19s
they are $600 plus the price to modify lower ball joint/steering arm. they are made by biocustomz(MAX FISH) and they are the shit. you shouldnt need them for an 18" though unless you want just want them
