Brake Booster
Brake Booster
watatoy avatar
watatoy
I have a 1994 Toyota pickup bd to the rockers on 20s. My wheels are just hitting the booster it would probably be fine because it only hits when its all the way down but i was wondering what years i can get for a smaller brake booster, how much smaller are they, do they bolt right up like the stock one and where's a good place to get them.
TwistedMinis avatar
TwistedMinis
Try the 79-83 2WD brake booster. Its 8" diameter, and same firewall bolt pattern. Depending on your truck, the master cylinder may bolt up, but I have heard of people having a different bolt pattern. Personally I have not experienced this. I have a newer master on my stock booster on my 80 Toyota. You will just have to adapt the push rod on the back of the booster to fit your pedal, I believe that is it.
skip1100 avatar
skip1100
I have a 92' with a booster off a 85' i think. Its the 8'' one. bolted right up no problems.
watatoy avatar
watatoy
cool thanks guys
s10tukin22s avatar
s10tukin22s
will a 87 work???
insaneautoconcepts avatar
insaneautoconcepts
Tacon19s avatar
Tacon19s
dude, I just moved mine over an inch and a half. what size tire are you running?
watatoy avatar
watatoy
Just want to make sure what year booster will work with the least amount of fabrication. Thanks. Also with getting a smaller booster does it effect the braking at all?
watatoy avatar
watatoy
anyone? Just wondering if it effects anything. Like braking wise.
laydouy94splash avatar
laydouy94splash
is there a difference betweem the 2x4 and the 4x4 booster off of an 1982 pickup
