valves
valves
chopedmazda
what kind are these?
ShakinPlates's avatar
ShakinPlates
Edited: 12/19/2007 2:57:23 PM by ShakinPlates
AFC is the brand. AFC 3/8" DUAL VALVE W/FREE FITTINGS[VALAFCDUAL38] $89.00
Click to enlarge 300 PSI
FILL & DUMP VALVE IN ONE COMPACT ASSEMBLY
MACHINED FROM SOLID BILLET ALUMINUM
6 MONTH MANUFACTURE WARRANTY
PLEASE NOTE: DO NOT CONFUSE THESE VALVES WITH CHEAP IMPORTED IMITATION VALVES THAT THE LEADING RIP-OFF COMPANIES SELL. These valves are from the original designer/manufacturer, AFC, which is a US based company that has been around for years building high quality valves for fuel delivery components. Each assembly is basically consist of two valves. One is to fill and the other is the exhaust (dump). For a FRONT/BACK system you will need 2 of these valve assemblies (which is like having 4 single valves). For a FRONT/BACK/SIDE/SIDE system you will need 4 of these valve assemblies (which is like having 8 single valves). Since they share one body, you will benefit in many ways:
1. LESS FITTINGS REQUIRED
2. LESS FITTINGS = LESS MONEY (you save $$$)
3. LESS FITTINGS = LESS CHANCE FOR LEAKS 4. LESS FITTINGS = FASTER INSTALL TIME
5. COMPACT DESIGN FITS IN SMALL SPACES
6. OVERALL CLEANER LOOK THAN CONVENTIONAL VALVES
7. GAUGE PORT BUILT-IN (no tapping into air lines)
Oh yeah, and AVS is throwing in FREE FITTINGS!!! Your choice of 2 straight brass D.O.T. compression fittings or 2 straight NICKEL PLATED push connect fittings and one 1/4" countersink plug for the gauge port. If you chose to purchase an air line fitting for the gauge port we'll switch out the plug to a reducer bushing. Don't forget to check all of your options below.
******************************************** goo to AVS's site:http://avsontheweb.com/store/product_info.php?products_id=1348&osCsid=c0ffd051ced29961d7448ada59b65a6a
