i need help with my s-10 v8 swap!!
demonykcustoms
i was wonderig if there was a place i can buy a wiring harness that will plug into my truck so its all labeled out and stuff? any help would be greatly appreciated.
shideburns's avatar
shideburns
what year?
i got a 89 with a v8 and live in phoenix if you need some help. i also have an entire harness (every wire on the truck) that is labeled that can be used for pretty much any swap on any car since you would be redoing it all.
layin22ʹs's avatar
layin22ʹs
hey bro check out the painless wireing 18 circut harness i paid 300 bux for one last year for my small block swap,it was nice rewired the whole chasis,everything was laid out for you realy nice way to do it man.
demonykcustoms
its a 86 and i have a carbed 350 out of a 85 c-10. will the harness you have work for me? if so how much do you want for it
Severed701's avatar
Severed701
why do you need a harness for the v8 swap if its an 86 and ur putting a carbd motor into it
F
framedragger
all you need it 3 wires to put the engine in.you can do away with the rest...u need a hot key on wire to youre coil....need a start wire to the starter and 1 wire from the alternater to the battery..i have done several of these swaps..the painless kit is a waste of money.
shideburns's avatar
shideburns
yeah you really dont NEED mine but if you want it $175. on each wire it says exactly what it is every 10" or so but like i said it is everything, new fuse box, tail light wires, ignition, EVERYTHING. if you need help you can look off my truck, there are really not many wires to screw around with. the V8 swap manual tells exactly what ones you need and where they are located.
demonykcustoms
i mainly need help figuring out which wire is what because the guy helping me before cut all my wiring up and didnt label anything then flaked out and wont finish the job. is anyone around 35th ave and bell that could come show me?
shideburns's avatar
shideburns
51st and union....call me, i will IM my #
