leaking
dk101284@aol.com's avatar
leaking
dkadventures's avatar
dkadventures
my blazer is leaking. i dont know which line the air is leaking from. it leaks from the tank and once the psi in the tank goes below the psi in the bags then the bags also then start losing air. what lines should i check out first? i kind of want to get this done before ludkrs so the ride is a little safer
standardbyker88's avatar
standardbyker88
spray bottle with soapy water onto the lines and fittings. look for bubbles. also, run check valves between the tank and the valves. it will prevent pressure drop in the bags. but check any lines into and from the tank first. id look for loose fittings first....
scotto79
double check your fittings for sure, I couldn't figure where my truck was losing air overnight when mocking up, turns out 1 fitting was a little loose.
cruisinlowS10
x2
