PLEASE HELP ASAP...
PLEASE HELP ASAP...
9
92yota
i was unscrewing a 1/2" brass PTC fitting out of my air tank and the hex shaped head snapped off. the threaded end of the fitting is still inside as is the metal sleeve. i have no idea how to get this out. im not sure if using an easy out bit would work in this situation? this is my daily, so i need to get it fixed as soon as i can. any suggestions?
bdroppeddak's avatar
bdroppeddak
break the sleeve out of it and use an easy out!
BK2LIFE's avatar
BK2LIFE
yeppo easy out is your best buddy here
Gotmods1
happened to me once, i used a die grinder to thin out the wall of the fitting. when the threads started to show i was able to pull out the threads like a coil with some needle nose pliers. installed a new fitting and all is good.
92yota
Edited: 8/14/2007 7:29:34 PM by 92yota
thanks for the help
bdroppeddak
is that a center punch?
Forever Draggin's avatar
Forever Draggin
no its a type of easy out, i got a few like that...i find the spiral ones are better tho, but glad to see u got it out bro...i done that same thing too
