got the front of my s10 bagged but....
tricktruxs10@hotmail.com's avatar
solows10's avatar
solows10
my upper control arm is about a 1/2 inch away from my clutch cycinder waht casn i do about this so the front will lay out the right way
i cut it's avatar
i cut it
i sunk my cluth master cylinder in the fire wall about 2inchs. but then u have to shorten the rod comming out of the master cylinder that goes to the clutch. good luck that was fun
solows10's avatar
solows10
do u have any pics of that
North East Kustoms's avatar
North East Kustoms
You will have to relocate the clutch slave cylinder. You can move it over or do what Chris said. Either way, you have to modify the rod from the pedal to the cylinder.
Or you can run 14" wires and it will lay hard.
