GC 450s
GC 450s
515customs
Theres three prongs on my valves. I know the flat one on the top is the ground. There are two on either side of the top one, if I only need one of them what is the other for. Can I use either side post as the possitive and if so why are there two?
railinisuzu's avatar
railinisuzu
Ithink its for if you want to run it to like a relay of some sort, or like the wireless remote.
balcar's avatar
balcar
use teh 2 top ones, bottem one is not for 12 volt, its there to look pretty. haha
515customs
If you hold the valve straight up so the fittings go in the bottome, And look at the side with the prongs on it thears only three prongs. one flat one one the top like this - and one own each side that look like this [ ] . the top one is labeled ground so which one should i hook up the possitive to?
