question about valves barking while airing up rear
12 following
freakwitafro@yahoo.com's avatar
FreakwitaFro's avatar
FreakwitaFro
when i air up the rear it tends to bark or chirp or whatever you wanna call it and its getting annoying. im wonding if anyone knows what might be causing it and if it could possibly be the plumging off of the expansion tank. thats where is sounds like its coming from but im just curious as to what others think might be the cause. thanks!
dragn168's avatar
dragn168
alot of pressure and 1/2" valves= barking shit just 1/2" valves will bark on there own even with like 160psi but if it sounds like a dying elephant than thats your tank shrinking cause your running to much pressure
lowdowndirtydawg
Yeah, Trev, vales will bark when the break in. Lord knows the blaze always barks. What happens is the dump valve uses back preasure to stay shut and when you fill them form nothing a little of that preasure escapes before it seals properly. Nothing to worry about.
cruisinlowS10
are you running parker valves? parkers are famous for their bark. I like that noise btw
Holeyguy66's avatar
Holeyguy66
mine have always chirped when filled
IB2LOUD's avatar
IB2LOUD
most times it's caused from the dump valves closing as the backpressure is added
to stop it you can just run a short length of air line from your dump valves
kaoss's avatar
kaoss
you could put flow controls on the dump valves also
FAT NICK's avatar
FAT NICK
take a 1/2" plug & drill a 1/8" hole in it.... put it in ur dump valve... it will slow it down when u drop it but it ill also quiet it down alot when u air it up
nryota's avatar
nryota
whos cares the louder the bark the better, thats why i went with 1/2" gc. there pretty damn loud. that and i got them at a good price!!
splashed
they also sell silencers
